Electronic format of speed transfer to info pannel
arvinfx
Hi, I am electronic student and i must build digital speedometer engine evolution for my 405 and i need real format of upper variables where sent from ecu to front panel pointers.
spider
- x 77
arvinfx
Hi spider,spider wrote:Hi.
As far as I am aware, the only speed sensor reading will be from the ABS sensors (one per wheel) , the speedometer itself is mechanical (cable driven) straight from the gearbox.
I should now about protocol of data transfer from (ecu) to (front panel pointer) , i never need mechanical information.
pug_owner2002
- x 3
spider
- x 77
Ah.
There's a sensor fitted to above the gearbox, I think it is just a hall effect sensor
, and this picks up a tiny, tiny voltage induced by the flywheel.
There is an amplifier for it in the instrument panel itself from what I remember.
Andy.
arvinfx
There is no need to read data from sensors the ecu support it.
I test pulse from ecu to front pannel and this result become.
engine evolution=(ECU Pulse ) * 30
e.g= 133 pulses we give from ecu in 1 sec
engine evolution= 133 * 30 = 3990 RPM
speed = (ECU Pulse ) * 0.8
e.g = when we give 130 pulse in 1 sec
speed= 120* 0.8 = 100 Km/h
Xaccers
- x 188
going off topic, you can't get us some good photos of the latest Saipa Xantia can you?
DIY sphere tool
DIY sphere tool
