i think i have a problem with the immobiliser in my C5 2.2 HDi. most of the time the car starts fine but recently it has decided to play up a bit. seemingly for no reason it will just turn over but there will be no sign of it actually starting. the first time this happened a warning came up saying something about immobiliser fault. i got out locked the door then unlocked it and it started first time. since then it has got a bit worse and is occuring more often, now i have to disconnect the battery and leave it for a while then reconnect the battery and start again. this has started happening since i tried to clear the service warning light by holding the odometer button for 15 secs whilst holding key in 1st position, this was supposed to be the way to get rid of the service warning light.
any ideas how to reset the whole jobbie pls ?
immobiliser problem
- x 1044
sijrayner
finally sorted out this issue, i was put in touch with a guy called pete who is an ex citroen engineer. top man he is, he had a look at car and immediately suggested it would be a burnt out connection on the ecu. it was, but even after he fixed it, by cutting out 2 inches of wire and fitting a new connector, (a five minute job) the car starts perfectly, he cleared all the fault messages (using a proxia, which he said is far better than lexia) and sorted some other bits out. charged me very little, (i had previously paid an indie garage £75 just to be hooked up to a lexia with nothing done) cannot recommend him enough.
why oh why did i buy a C5.
citroenesque
- x 4
Well I think you can recommend him higher:- name and contact details please
(PM don't post phone numbers)
1997 Citroen Saxo SX 1.6i Auto, Fijian blue, 60k mls
2004 Citroen C5 Exclusive SE 3.0 V6 Auto. Silver. 114k mls
2006 Citroen Xsara Picasso Desire 1.6 16v, Sahara bivouac (beige). 128k mls
2008 Citroen C1 Vibe, red. 74k mls
- x 1044
sijrayner
will pm details, he talks a bit but has 30 odd years experience on citroens, still drives a xantia himself. and knows all the problems.citroenesque wrote:Well I think you can recommend him higher:- name and contact details please(PM don't post phone numbers)
also he is local to us Essex 'boys'
- x 1865
And I think that the Lexia is just plain awful. I'd hate to use the Proxia then!!!wheeler wrote:In my opinion though Lexia is far more user freindly
- x 5580
Put his contact details in the Recommended Garages & Services forum.sijrayner wrote:will pm details, he talks a bit but has 30 odd years experience on Citroëns, still drives a Xantia himself. and knows all the problems.citroenesque wrote:Well I think you can recommend him higher:- name and contact details please(PM don't post phone numbers)
