Do I need to change the water pump when replacing the timing belt on my C5? Cheers.
Would I get away without doing replacing the water pump?
Cheers folks.
Timing belt change C5 2.0 HDi do I change the water pump too
gazzas c5
CITROEN C5 2.0 HDI VTR 04 REG
CITROEN C5 2.0 16V EXCLUSIVE 53 REG
CITROEN C5 2.0 HDI EXCLUSIVE 52 REG
CITROEN C5 2.2 HDI EXCLUSIVE AUTOMATIC 54 REG FACELIFT MODEL
CITROEN C5 1.6 HDI VTR 05 REG FACELIFT MODEL
spider
- x 77
It's advisable to change it, simply as (assuming there's no sign of leakage typically whitish crusty stuff around its sealing edge) they can start to leak a short time afterwards if you are unlucky.
It's just sensible to change it at the same time really, to avoid another stripdown a few months later.
Up to you though obviously
, there was no requirement as such to replace it with the timing belt, although it would obviously be inspected at that time.
Andy.
