help i have a Citroen c5 estate hdi diesel engine.i am having problems with
power the car was dragging going up the gears ,i serviced it all filters and took a injector out that was blowing.it ran fine for about 5hrs and then whent back to old problems,if i tickle the throttle it will go up ok if i put my foot down it seems to choke it.also now and then the antipolution warning light comes on any help plse
fuel problems
Onlinemyglaren
- x 5692
A little bit more info might help.
Year, Model, Engine/BHP.
There are quite a few things it may be. One recurring problem is the MAF. You can sometimes effect a reprieve by cleaning it with carburettor cleaner. Be very careful as they are delicate, if you touch the wires it is ruined and they are around £100 to replace - don't even consider the cheap ones off eBay.
I have a similar problem - my turbo won't boost until >3,000 revs is reached and the car is a bit of a slug. I suspect a leaking/split vacuum hose and have just dropped the car off to get it seen to as I'm too idle to poke around with it myself - plus it's raining
Loss of power does generally seem to centre around the vacuum hoses and electrovalves that work the turbo, EGR and fuelling.
citroenxm
- Fallen Hero
- x 70
A blocked particle filter can cause engine restrictions, have discovered this myself with a 2.2 hdi...
We had anti pollution warnings, and a blocked particle filter warning, and the engine would only rev to 3k...
After removing the front section of exhaust to get at the filter the engine now screams to 5k!
So next job is to clean out the filter....
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
cachaciero
- x 9
Re: fuel problems
jimbo1955 wrote:help i have a Citroen c5 estate hdi diesel engine.i am having problems with
Without knowing which engine it is anybodys guess however the systems you describe are classic for a MAF failure on any modern HDI diesel.
As I always say get it on a Lexia and find out what is really wrong.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
