ABS sensor
DaveW
ABS sensor
Unread post by DaveW »
Can anyone help with a part number please.
The front O/S ABS sensor on my X reg (2000) Xantia 1.8i, 16 valve hatch has given up. GSF want £62.50 for a replacement but I have seen some on fleabay for around £25 - just need to make sure the part No.s match.
Interestingly, when I checked the resistance readings at the ECU plug, the dodgy one gave a high reading rather than the usual open circuit, zero reading. The other three all showed a reading of 1.1K but the dud showed 6.4K and this was confirmed when I unplugged it at the front sub frame connector.
Sorry to have to ask for this info but I seem to have lost the site address for Citroen service (tool box) - anyone?
Dave.
Xantia Forte 1.8i, 16v X reg.(09/2000) 93K, aircon
Toby_HDi
x 3
Unread post by Toby_HDi »
Service Citroen shows the ABS Sensor as 4545.73. They are the same for all Xantias (with ABS obviously)
Something to bear in mind when buying parts of Ebay is the quality. Certain items I have heard are not so good. Not heard anything about the ABS sensors though.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hang on there Toby... Be sure.. Same for all S2 XANTIAS!!
As S1 Xantias used a different system, with different sensoors...which dont seem compatible...
Paul
A very sad...
1994 XM 2.1 d auto
DaveW
Thanks , Toby.
RE:
Toby_HDi wrote:
.......... They are the same for all Xantias (with ABS obviously)
I thought I had read somewhere that the sensors for pre- facelift and post- facelift models were different lengths?
Dave.
citroenxm
Fallen Hero
x 70
EXACTLY what I have just said above... I think Toby meant All S2 Sensors are the same and theres no engine difference to the sensors....
Paul
A very sad...
1994 XM 2.1 d auto
DaveW
Paul,
Yes, sorry to repeat your words - my one finger typing is too slow and you beat me to it!
The part number matches the one on ebay and I have asked the seller to confirm suitability.
Do you have the web address for Service Citroen? I still have my log-in details but have lost the site address.
Dave.
x 94
Unread post by citronut »
here are two part No.'s for MK1
96 113 241
ABR SENSOR
AV
- WITH ABS BRAKES UNTIL RPO No. 06443
4545 43
AV
- WITH ABS BRAKES SINCE RPO No. 06444
and here is the one listed for MK2
4545.73
regards malcolm
Toby_HDi
x 3
My apologies. I meant all S2 Xantias.
Toby
Previous:
citroenxm
Fallen Hero
x 70
DaveW wrote:Paul,
Dave.
No I dont have, I did have a spare sensor, I did have a sensor, but it promised to someone also needing an S2 Front sensor...
Paul
A very sad...
1994 XM 2.1 d auto
HDI Dave
x 3
Unread post by HDI Dave »
I'm in the same boat, front O/S, mine shows zero reading.
I spied this on the bay,around £15 including p+p,top feedback:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
When I had a quick look at replacing it, it looked like a pain of a job,wire routing etc,so I left it!
Really must get it done..my garage bloke who takes it for the mot, gave me a stern look last mot,(abs dash light's on),as I said I'd sort it...2 mot's ago :oops:
Opinions on the above 'bay item? Surely can't go wrong at that price?
1999 Xantia LX 2.0 HDI 110 Rusteration project...
DaveW
The wiring route is not too bad.
Once you are under the car you can just about reach the connector with both hands (well fingers!) where it sits on the cross-member and from there to the sensor the cable is held mostly by grommets pushed into slotted brackets.
Dave.
jgra1
(Donor 2021)
x 37
Unread post by jgra1 »
daft question, but are the front and rear sensors the same? i have two gone... s2 xantia John
VertVega
x 13
Unread post by VertVega »
jgra1 wrote: are the front and rear sensors the same?
The front and rear ABS sensor heads are different.
Rear sensor is "resting" over the ABS ring and front is more like "pointing" towards it.
x 94
John
part No. for a MK2 rear sensor is
4545 74
ABR SENSOR
AR
regards malcolm
jgra1
(Donor 2021)
x 37
thanks both :D
