Long life engine
XantiaDaveEire
x 4
Long life engine
Unread post by XantiaDaveEire »
Iv now done 154,000 miles in my car and would like to do another 154,000 :lol:
So what is needed to keep the engine going and going ....
Other than regular oil changes and timing belt changes ,what else should be done to maximise the life of the engine
Dave
1998 Xantia 1.9 TD 186k
2008 C4 grand Picasso exclusive 105k #-o
JohnD
(Donor 2022)
x 72
Re: Long life engine
Unread post by JohnD »
If you do that, you're doing your utmost. Maybe keep coolant changes up-to-date and avoid short journeys.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
robert_e_smart
x 14
Unread post by robert_e_smart »
Its not the engine thats going to let you down its all the other stuff on it. Be very particular about the diesel you use as well, and avoid veg oil at all costs.
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
Xaccers
x 188
Unread post by Xaccers »
robert_e_smart wrote:and avoid veg oil at all costs.
Nothing wrong with using vegetable oil, it does no harm to the engine or the pump, if anything it is beneficial as it lubricates better than derv.
DIY sphere tool
Deanxm
x 87
Unread post by Deanxm »
it does eat pump seals though, and form the most gooey hard to shift gunk known to man when it leaks! think your right though it wont hurt the mechanicals at all.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Xaccers
x 188
Doesn't eat the seals, as they age like all seals they go hard (think of the cam cover seal) and stop sealing properly.
With derv this isn't a problem, it leaks slightly and isn't really noticed.
With veg it works into the gaps made by the old seals and expands when it cools increasing the gap.
The gunk has amazing protective properties making the engine bullet proof (literally) ;)
DIY sphere tool
JohnD
(Donor 2022)
x 72
robert_e_smart wrote:Its not the engine thats going to let you down its all the other stuff on it..
It's a '98 Xantia he's talking about. It's a bit like our '98 P306 - look after the engine and there's not much else to worry about - unlike the C5.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Xaccers
x 188
Dave, what's the condition of your strut tops and engine mounts?
DIY sphere tool
XantiaDaveEire
x 4
Engine mounts ?? :oops:
Strut tops are fine and shouldnt be an issue
HDI Dave
x 3
Unread post by HDI Dave »
Agreed,
My trusty old petrol Fraud Mondane-o had well over 180,000 miles under its belt and still ran sweet.The body was solid, unlike my xant,tinny in comparison...I replaced suspension/w/bones/brakes/zorst,then ran it till everything wore out around 5 years later. In the end the gearbox died,but the engine was great,no smoke even..
..and yours is a diesel..heck, it's only just 'run in' :lol:
I'm sure I've seen diesel taxis that have done around a million miles on the net somewhere???
1999 Xantia LX 2.0 HDI 110 Rusteration project...
Xaccers
x 188
XantiaDaveEire wrote:Engine mounts ?? :oops:
Three engine mounts, one on the inside of the O/S wing under the plastic cover which routes the fuel and aircon hoses, U shaped with a pyramid like bumper front and back, sitting on a black grenade sized dampner.
One donut shaped down at the back behind the sump, and one on the gearbox under the LHM resevoir area.
DIY sphere tool
