Antipollution with Lexia
WaveyDavey
Unread post by WaveyDavey »
Hopefully someone local is going to help with a Lexia :-)
Will the Lexia diagnostics show low vacuum pressure if there's a leaky pipe?
David
cachaciero
x 9
Unread post by cachaciero »
Doubt it as far as I know there is no sensor that measures vacuum pressure.
What you need is a vacuum gauge and some small plastic T Pieces.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
kaostheory
Unread post by kaostheory »
Vacuum for what?
Where are you located?
What are your symptoms?
