berlingo dw8b egr vacuum box? identification help
Post Reply
finny
My Cars:
Post by finny »
hi, could anyone tell what the plastic oblong box located under the egr solenoid is called, its got 3 vacuum pipes going in/out, one is for the egr solenoid, one pipe heads under the the air housing towards the egr valve and the in one comes from the vacuum pump, ive got a pipe broke off and ive been told to make sure its all connected up before i have it read for faults on a hesitation problem which is suspect is something to do with the advaced solenoid on pump, i have a part number but have tried with no luck to find anything 96415 367.80-00. thanks
My Cars:
x 92
Post by citronut »
hi and welcome
are you sure that is a proper part No.,
as i have just run it by service citroen and it came up as no documents found,
if you give me the last 8 digits of you chassis/VIN No. i will check it out with that, as it will give me you precise wagon,
were abouts in Kent are you im in St Leonards on sea East Sussex
regards malcolm
My Cars:
x 92
Post by citronut »
i just had another look at service citroen and think this is the part No. of the part you are talking about,
1628 LQ
ELECTRO VALVE
DW8B DIESEL AND EEC 2000 DEPOLL (ENGINE)
sorry i havent masterd the art of transfering diagrams from service citroen as yet,
although i have mahaged to copy it to coral photo house on my computer (thats half way there)
regards malcolm
finny
My Cars:
Post by finny »
my vin is VF7**************[VIN obfuscated, can be read by forum staff]. i just had a quick look about and a 1628 lq is an electric solenoid used across the citroen/peugeot range, i dont think its the part, the part im trying to identify has just 3 vacuum pipes no electrical connection, its bolted directly under the battery right next to the egr solenoid, it must be something to do with egr i think, ive searched google high and low for this one, the part number? 96415 36780-00 is on the plastic unit, possibly not the part number?, even the bloke at the citroen specialist said i needed to sort that part out first what ever it was, the manufacture date stamped on it is correct for the van year. thanks for your help and the welcome to the forum, im from deal area up past dover way
spider
My Cars: Soon, I hope...
x 77
Contact:
Post by spider »
I know the part you are thinking of and have seen it on (most) DW8 engines. I think its just a pressure (well vacuum) ball valve assembly.
There are no pictures that I could see (bear in mind I only have Peugeot docs, although they are 99% the same) I looked at both 206 DW8 and Partner DW8, although I could not find it anywhere :(
I do know what you mean though. Its got rounded corners (usually) and has a few tiny vacuum pipes into it.
Andy.
finny
My Cars:
Post by finny »
yeah thats it with the rounded corners and the pipes, it sort of looks like a black plastic sunglasses case, i cant find anything on google about it, im getting a fault code check but the garage said if its not corrected it might throw up all sorts of faults
My Cars:
x 92
Post by citronut »
ok then this must be the part/No. and price,
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
0000162774 VACUUM RESERVE 11.81 GBP 13.88 GBP 13.88 GBP
it is rectangular with rounded ends, two pipes comeing out of the top and the pipe from the vac pump plugs into the end,
i come from Folkestone and the other half comes from Dover,
i also have a nephue and a sis inlaw live in Deal,
regards malcolm
finny
My Cars:
Post by finny »
cheers bud thats what it is, my pipes come out the side but ive seen the exactly the same thing in a pic with the same pipes coming from the top, trip to canterbury citroen for that if thats all it cost, i expected something like £40. so you will know the deal area then, im just outside halfway to sandwich.
My Cars:
x 92
Post by citronut »
that part No. is what comes up with your chassis/VIN No.,
tha diagram i explained is not always an exact drawing, even though they usualy are,
its many years since i was nlast in deal so cant recall,
my brother inlaw used to be a milk man in Deal,
if you know Folkestone my Dad owned/ran the pottery/shop on the old high street,
regards malcolm
Post Reply
