Xantia HDI Volume of Coolant
thorter
x 44
Unread post by thorter »
Does anyone know the proper amount of coolant for a Xantia HDI 110 with aircon? According to the Citroen 2001 Xantia-XM-Synergie book, Revue Technique, and the BOL, it is 8.5 litres without aircon and 11 litres with aircon.
Seems clear enough, but that means an extra half gallon of coolant when there is aircon. Now as far as I can determine the radiator, heater matrix, and engine block are the same with and without aircon, so what would account for 2.5 litres extra? Is it just a mistake, and the correct volume is 8.5 litres for both?
Fred
Toby_HDi
x 3
Unread post by Toby_HDi »
11 litres is correct.
Unless you're flushing through then you may find it won't take the full 11 litres. Though flushing through isn't a bad idea.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
falling-out-with-my-car
x 25
Unread post by falling-out-with-my-car »
isnt there an extra rad for the air-con?
Toby_HDi
x 3
falling-out-with-my-car wrote:isnt there an extra rad for the air-con?
Yes, also known as the condenser. Don't think any coolant runs through it though. Just relies on air cooling the refrigerant down. Could be wrong though.
Toby
Previous:
x 1489
Toby_HDi wrote: Just relies on air cooling the refrigerant down. Could be wrong though.
Yes, you're (almost!) right - the extra radiator just condenses the refrigerant back into liquid and is air cooled only. Not sure where the extra coolant is required when AC is fitted - perhaps the rad itself is bigger?
thorter
x 44
Thanks Toby, I'll allow for 11 litres.
Its still not obvious where the extra half gallon is needed. The radiator end connections have minimal volume, and it is only the sump that has clearance for the aircon compressor (hence the reduced oil content).
Fred
