Smokey TUD5
mark21td
Smokey TUD5
Unread post by mark21td »
Hi Guys
I need some help,
I've brought a 1996 106 1.5D (same as a saxo) for my doughter's 18th with 66K on the clock,
It's got a smokey engine (blue smoke) and only runns on 3 on startup (with black smoke for a few seconds) which is probably glow plugs,
It's had a new rad so I thought it was head gasket after overheating,
so I pulled the head off today and all looks good !!!!
can still see machineing marks in the bores,
It's had a new cambelt and oil change before I got it but the air filter is quite durty,
The EGR looks to be closing properly (although the inlets/outlets are quite oiled up) and the valves look to be ok,
My thoughts are either valve stem seals or pump timing.
Has anyone got any other ideas ?
Oh and I have no manual so how do I check the pump timing when it goes back together as there doesn't seem to be any lockoff point on the pump, and can somone tell me what the head bolt torc settings are.
Thanks in advance
mark
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
JohnD
(Donor 2022)
x 72
Re: Smokey TUD5
Unread post by JohnD »
JohnD wrote:
mark21td wrote:Hi Guys
Max bolt length is 197.5mm.
Tighten to Stage 1....... 40Nm
Stage 2....... 50degrees.
Sequence
8 4 1 5 9
.................................... Flywheel
7 3 2 6 10
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 94
Unread post by citronut »
you could always buy the brand new TUD5 engine i have still on the pallet it came from the factory on, comes with OE cam belt and oil filter,
regards malcolm
mark21td
Re: Smokey TUD5
Sequence
8 4 1 5 9
7 3 2 6 10
Thanks John
mark21td
citronut wrote:you could always buy the brand new TUD5 engine i have still on the pallet it came from the factory on, comes with OE cam belt and oil filter,
regards malcolm
It's tempting but my Budget is tight and I have a 30K accedend damaged car lined up for £200 if I need it.
mark21td
Has nobody else got any ideas.
Could it be down to pump timing ?
JohnD
(Donor 2022)
x 72
Easy enough to check the timing. Take off the top over and use two 8mmx 50mm bolts. One should go into the Cam sprocket at about 4 o'clock and the other in the pump sprocket at 1 o'clock. Also a 6mm drill shank should enter the hole in the flywheel casing.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
mark21td
Thanks John, I'll make sure it goes back together right.
