Picasso Tyre Wear
PicassoPigeon
Picasso Tyre Wear
Unread post by PicassoPigeon »
Front drivers side tyre is worn on inside and outside edges, I have knocking noises which must be the drop links but I didn't think they caused odd tyre wear?
Thanks.
2002 Citroen Xsara Picasso 2.0HDi
125,000 miles
x 94
Unread post by citronut »
your right drop links cant cause tyre wear, usualy the cause of a tyre's wearing on both edge's is low tyre presure,
regards malcolm
x 1240
Unread post by Peter.N. »
Unusual for the drivers side to wear more, its usually the n/s that wears first. I think it must be a Malcolm says, low tyre pressure or a faulty tyre.
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
The bottom ball joint or suspension arm have to be the prime suspects for me. Try using a pry bar between the suspension arm and hub then lever the bar to check for movement in the balljoint, you may need to separate the joint to get an accurate assessment of wear. Also examine the rubber inner bushes for deterioration.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 94
usualy lower swivle or arm bush movement will cause one or the other edge to wear, not usualy both edge's,
when tyre presure's are low the centre of the tread bows upwards, then you are just running on both outter edge's,
regards malcolm
x 1240
I agree with Malcolm, any misalignment will cause wear on one edge, if both edges are worn evenly that sounds like normal wear, I suppose the wheel is going round :shock:
fred1
Unread post by fred1 »
Check your track rod end ball joint for play on the side that is suffering tyre wear.
If the play is excessive it could cause the wheel on that side to go outside the tracking limits both ways, one way when accelerating and the other when braking, causing wear on both sides.
The ball joint will also knock quite a lot !
John
DickieG
x 33
I'm working along the lines that an under inflated tyre won't be causing a knocking noise, well not in my experience :lol: a knocking noise and unusual tyre wear is normally down to wear in one of the hub locating points as mentioned in my earlier post or the track rod end balljoint by John above. The only other option is an underinflated tyre AND a worn joint such as a droplink.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
x 1240
I had forgotton about the knocking noise :oops:
x 94
yes but Gav thinks the knocking is drop links, and these certailly cant cause tyre wear,
and if it were a track rod end it would definetly cause exactly the same wear on the other front tyre (one edge or the other ) dependant on towing in or out,
and i dont feel wear on both edges to be normal tyre wear, because if all were well the tyre should wear evenly across the hole tread face
regards malcolm
PicassoPigeon
Its only knocking when I go over speed humps or broken roads. On closer inspection the wear is worse on the inside edge. Could this be caused by my straddling the speed cushions that I have to negotiate each day, if I am having more of said drivers side tyre on the cushion than the passenger tyre?
125,000 miles
DickieG
x 33
To clear things up here Gav, have you checked the tyre pressures as being correct? The knocking noise is almost certainly down to wear in a joint somewhere.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
x 1240
Wear on the inside edge would indicate tow out.
PicassoPigeon
The pressure in all tyres are fine I check them quite regularly, just never checked the wear on the inside until the other day when parked on full lock.
125,000 miles
x 94
Peter wrote
"Wear on the inside edge would indicate tow out."
only if it is both tyres wearing exactly the same, not if its one tyre on one side of the car,
regards malcolm
