Any Ideas on this strange parts (CV joint) problem:
For my xantia II estate, year 2000, I ordered an ABS CV joint. They're meant to be the same , reagrdless of estate or saloon. Citroen tech list the driveshaft as per my VIN, as No. as 3273 9W
The CV joint for '93 to 2001 models, I received is 135 mm long, but the one I've taken off is 143mm approx: (SEE PHOTOS BELOW). Basically the the input stub is too short, indicating that the hub for my car is different form the usual standard large caliper/disc hubs that are fitted to V6/Estate models.
The supplier (J&R TRading - a fairly old firm) says he's supplied thousands aover a good number of years, and they are all the same. He wouldn't give me the part number it's meant to replace, possibly because Citroen don't list it - only the entire driveshaft; he says he gets his technical info from Citroen, but possibly his parts are chinese manufactured. He cannot think why mine is different, he's never before had such a query, and wonders of anything has been changed. I don't think so, the hub carrier and all that is factory fitted - I can see it's original CItroen fittings, down to the gaitor clips. But his statement about them being all the same (in his experience) sounds convincing.
So to get my car going again I need to solve this awkward problem, and find the part.
CV joint (MKII ABS) input stub - strange one
John Plum
- x 5
John Plum
Xantia II Estate,1999, 2.0 HDI LX, 17000 miles, manual
John Plum
- x 5
More info:
There is a CV joint with a longer stub that J & R Trading know of, for HDI vehicles with larger brakes, but they have 39 internal splines - 39/25 spline CV instead of the usual 34/25: in other words the one they supplied shouldn't go onto my driveshaft, but it does, so my driveshaft has 34 splines to fit the CV joint.
John Plum
John Plum
- x 5
It seems that the 1.9 TD driveshaft is the same as the 16V fro 1995 onward, (with 48 ABS ring teeth). THis too is supposed to have the 135 mm length CV joint with 34/25 spline stub. I think I'll have to go to the citroen dealer to get an answer for this. It must be something to do with the hub carrier being odd too. I might have to change hubs and driveshafts together one day in the future if spares are a problem for this particular car.
John Plum
John Plum
- x 5
Solution
What I'm going to do is use the old CV stub, rebuild the cage and bearings from the new as donor, and shrink fit an rust resistant ABS reluctor ring from www.ukpartsdirect.com (£14.99 + @2 pp)
Still would like to get the low down on this oddity...
John Plum
- x 1240
John Plum
- x 5
addo
- Sara Watson's Stalker
- x 95
I went through these questions in my "Wanted - Caliper Carrier" thread.
Your findings interest me as they challenge my assumption about the different driveshafts. Can't beat actual measurements like you have taken! Thank you for posting your findings.
Diesel models of the Series II did have the wider track, as did anti-roll petrol cars. Larger diesels and V6 cars had bigger CV joints and boots - easily compared to the four-pot sizes.
John Plum
- x 5
Hi Addo:
From your thread,
You said you wanted "Series II Activa (turbo, not V6) drive shafts" - I'm not sure why? (the V6 turbo driveshafts are listed as the same from exchange parts comanies that I've seen...) Bear in mind, J&R trading stated that they've sold thoudands , and never had this query come back - the estate and saloon ABS CV joints are all the same - V6 and Turbo.
You ask 'how rare are XUD9's on the UK with AL4 boxes', and think it must be very rare. That's what I've got - an estate version with the large 288mm disks, carriers and pads:
I suspect that on the AL4 TD Estate I've got may have NORMAL length driveshafts and it is the hubcarrier and CV joint together which are giving the extra 10mm length.
From your thread,
And, you asked where the length was, and were told it is on the driveshaft, as cv stub length wouldn't give wheelbase extra length, which is true. However, my stub is also 10 mm longer! - and fits the larger carriers I have on my car, an estate. (I'll get some comparative photos tomorrow) ...Handy man said: all the Xantias fitted with the ML5T or AL4 gearboxes, Activa, 110HDi, V6, etc have a wider track and longer driveshafts. I believe the extra length is about 10mm per side. You can normally tell as these cars also have wider front wings!
John Plum
John Plum
- x 5
Here are the comparative images:
The one on the left, my original factory fitted, is longer. In the Second photo you can clearly see the extra 10mm space between spline and thread.
The overall lengths are 145mm (left pictured CV housing) and 135 mm (right pictured CV housing)
John Plum
- x 1240
John Plum
- x 5
No, the abs ring was removed, ready to refit a new one. It's the CV housing off my car, which was fitted with ABS.Pete Write: The first one is non ABS, is that the difference?
I think what I've found is that, for xantias with wider front wheel base (AL4 cars), the norm is longer drive shafts, extended by 10mm (supposedly). BUt for my car, AL4 estate with wider and with large discs, it is the hub that extends the wheel base, not the driveshaft. I don't know how rare that is, or whether it is the norm for those cars (which I doubt as according to J&R trading). I haven't measured the driveshafts on my car - no need to at this time, and I don't see why on earth they can be longer if the hub carrier sends the wheels out by 10mm. .....
.... which means caution when ordering/swapping over replacement driveshafts, CV joints and hub carriers with this kind of spec xantia.
John Plum
- x 1240
addo
- x 95
Really appreciate that photo - ta. It's exactly what I'd have liked some weeks back. Not to worry; I have suitable driveshafts to pillage occupying the floor at chez jgra1.
I believe your car is 100% original. The part you've shown to be different, surprises me as you'd think that it would be cheaper to machine less versions of that piece as it's threaded and splined, and simply make different lengths of the centre section which only has CV couplings welded on. Can't argue with the evidence - I must owe you a beer.
John Plum
- x 5
addo
- x 95
