Brake pads for my HDI 2.0
Xantic
x 11
Unread post by Xantic »
How can i check which brake pads will fit my Xantia Exclusive 2.0 HDI.1999 v reg.
I need to order some but obviously i do not want the wrong ones to turn up as per usual with most places.
Any hints or tips.
Vin number is as follows if anyone has the capabilities of checking for me please.
Thanks in advance if anyone can help.
Russ..
Jaguar 2.0 Diesel
Peugeot 407 Diesel
LIVING THE DREAM
Russ..
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Simply order the largest size available for a Xantia IIRC 288mm
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Koukku
x 8
Unread post by Koukku »
Your HDi has the same brakes as TD and V6 (and probably Ph2 TCT/Activa too), ie. 288mm front discs.
I highly recommend Ferodo Premier pads: FDB1114 / FDB615 (front/rear). They are a bit more expensive than their oem replacement pads (FSL1114 / FSL615) though. I've ordered mine from http://www.rockauto.com.
- Previously Activated -
