Bleeding C5 Brakes
Gregg1100
x 5
Bleeding C5 Brakes
Unread post by Gregg1100 »
My son`s 05 C5 VTR has an n/s rear brake calliper that has corroded right by where the pad retaining pin goes through. We will get a replacement calliper from a local factor.
The question is; do you bleed the brakes the same way as the Xantia 2 .???
Thanks,
Greg
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
x 1055
Unread post by wheeler »
The C5 has a conventional braking system so to do it without a pressure bleeder you would need somone to pump the pedal unlike the xantia where you can let the HP pump do all the work.
Remember it uses standard DOT 4 brake fluid, not LHM/LDS.
