Access auto gearbox filler plug..!
John Plum
x 5
Unread post by John Plum »
Just a quickie, sounds stupid, but how exactly do I get to the autobox (AL4) filler plug and where is it!
I can't see it. Memory tells me it's accessible from behind the wheel, after removing the wheel and splach cover.
Do I go from the top of the engine, or from behind the nearside wheel or where?
John Plum
Xantia II Estate,1999, 2.0 HDI LX, 17000 miles, manual
hirsty
x 9
Unread post by hirsty »
If you remove the air filter housing and look down it's sitting on top of the box. I rigged up a funnel and pipe to refill mine cos it's a PITA to access without spilling and at £8/litre it's liquid gold.
Keith
98 Xantia Mk2 2.0 16v Auto Exclusive 160k + Now gone to Citroen Heaven
2004 C5 Mk 1 2.0 8V VTR Estate - current. Now with leather.
Sid_the_Squid
Unread post by Sid_the_Squid »
As said already it's on top, under the air box, acces is improved if put into 2nd gear, there is a few pics on this forum do a search, I'd post a link but pressed for time at mo
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
John Plum
x 5
cheers folk. that'll do. Glad I asked. :P
John Plum
Clogzz
x 40
Unread post by Clogzz »
10 mm bar filed to 8 mm at plug end.
