high speed problem..
Xantia94
Unread post by Xantia94 »
what could be the problem? my car run approx. 120~130 km/h and it shakes alot.. i mean ALOT.. usually it can go 140~150km/h smoothly.. some advice is appreciated..
cheers
NEWB :')
Xantia 2.0i 1994
spider
x 77
Unread post by spider »
Usually wheel balancing is the first thing to try. I bet a weight has come off. More likely with the adhesive ones (typically fitted to centreless wheels)
120 kph = about 70 mph so should be OK.
Andy.
Xantia94
planning on that, hope it is the weight problem.. nothing more.. haha
thanks..
NEWB :')
Xantia 2.0i 1994
x 1240
Unread post by Peter.N. »
...or it could be ply seperation causing a bulge on a tyre.
x 1459
Unread post by xantia_v6 »
Does the shaking stop if you ease off the throttle at the same speed, or do you have to slow down? If the former, then it could be a bad engine mount, the V6s certainly go like that, at about that speed. Wheel balance always shows up at lower speed, tyre separation usually at lower speed.
