Hi All
Above vehicle no blower, done the usual checks, it's driving me up the wall (I m ust be getting to old for this) cannot make sense of the diagram to fit relay, fiting relay not the problem just where the wires are, now it's getting dark, car going in for CT (French MOT) tomorow, and th car is in bits.......help please
many thanks
Stephen
1994 xantia with A/C blower problem
fridgedoc
Bonne Chance
Stephen
LHD Xantia 1994 (deceased)
LHD Xantia 1995 Berline
Stephen
fridgedoc
admiral51
- (Donor 2026)
- x 391
Im assuming you are talking about the relay mod for the interior blower??
The wires that the mod refer to are located under the steering coloumn shroud which on a 1994 will mean the removal of the steering wheel
Any more info about the problems as you mention A/C in the title,the blower is independant of the A/C
Colin
Colin
fridgedoc
fridgedoc
Thanks for the posts guys.
Stripped out the fan assembly, took it apart 12v to fan motor, running OK
reassembled and refitted fan ass'y turned ignition on and hey presto all working, tidy up rest of the "mess" but leave it so I can get to everything and test and check for a few days as I'm off to Sunny??? Brittany for a couple of weeks, next week, it's about a 4.5 hrs drive so must have fan running, I might even need to turn the A/C on
And it flew through the CT. (french MOT) phew!!!!
Bonne Chance
Stephen
Stephen
