Diagnostic socket in 1998 Xantia
JamesQB
x 5
Unread post by JamesQB »
Finally just bought myself a Lexia which should be winging its way to me soon. Noticed it comes with 30-pin cable but not 2-pin one and I forgot to check before buying it. :? Does anyone know what diagnostic socket a 1998 Xantia 1.9TD uses?
Just curious if I'll be able to check my parents' car over, really.
Honda Civic 2.2 CDTi 2006
Peugeot 407 2.0 HDi 2007
Toby_HDi
x 3
Unread post by Toby_HDi »
I believe that'll have the 16-pin connector.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
andmcit
x 30
Unread post by andmcit »
It is a brown rectangular 16 pin plug under the steering column
by the fusebox.
Andrew
JamesQB
x 5
Thanks for the information. Is there much need for me to try to get a 2-pin cable for the Lexia, or is it only used on very old Citroens?
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
JamesQB wrote:Thanks for the information. Is there much need for me to try to get a 2-pin cable for the Lexia, or is it only used on very old Citroens?
I wouldn't have thought, the two pin was pre Xantia and even then they only throw up flash codes which can be replicated by using an LED.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1055
Unread post by wheeler »
Mk1 xantia has the 30 pin socket & the mk2 has the 16 pin socket.
Wouldnt bother with the 2 pin socket unless you work on a lot of AX's,ZX's or older XM's.
addo
Sara Watson's Stalker
x 95
Re: Diagnostic socket in 1998 Xantia
Unread post by addo »
JamesQB wrote:Finally just bought myself a Lexia which should be winging its way to me soon.
That's good news. With the amount of car and mechanic grief you've had in the past, it has to be a massive step forwards.
I bought the two-pin connector with mine out of idle curiosity, to see if it would paint a different picture to the flash codes on my 405.
JamesQB
x 5
It should be, especially as it will allow me to program in the new injector, and as both sides of the family have Citroens, it'll hopefully prove invaluable.
After finding the turbo in the C3 seized, I've now finished stripping it down and cleaning it all and will be refitting it over the next few days. Fingers crossed that's the end of it then and we'll finally have a working car! :shock:
I looked more closely and realised the 2-pin connector is included with the Lexia kit I've bought... didn't realise.
Thanks everyone for the help.
