speed
mjwells
no you havent made a mistake the car is fine but it takes a good driver to master the zx.
possibly you might need some extra driving lessons because when you go from a family car like the astra estate to the super quick zx 1.9 d it might be a little unnerving. the gas pedal needs to be pushed down a little harder than the family car though.
blueboy2001
jeremy
ZX D's need plenty of welly to get them to go nicely and I still find this strange when i drive my wife's - even after 6 months.
Is your throttle opening properly? there seems to be quite a bit of urge right at the end of the travel and it may be that it isn't opening quite fully. To check get someone to sit in the car with their foot right down on the pedal, then look at the pump and find the end of the cable. Pull the end of the outer cable back and see if there is any movement If there is move the clip forward - ie towards the cambelt as far as you can. The cable should be tight now and you should have a fully opening throttle.
jeremy
jeremy
rabenson
I'm not on commission, honest[;)], but try a bottle of injector cleaner. I know I keep banging on about this but it reall can make a difference when coupled with a few high speed runs to degunge the engine: particularly if the previous owner was one of the "never over 2500 rpm" brigade. Got to be worth a fiver to try!
