ZX wobble!
berlingo_neil
ZX wobble!
Unread post by berlingo_neil »
Hi chaps,
This isn't actually my car, it's one i went to view this morning.
It's a 1996 ZX 1.9td, 152k on the clock & in quite reasonable conditon The seller picked me up & soon after it became apparent that it had some 'issues'!
The problem seems to only afflict 3rd gear - when accelerating reasonably briskly in 3rd the whole car seems to wobble - there are no graunching sounds or really anything untoward, but it's quite severe & the gear stick shakes also. If you left off the power the wobble stops. :?
I thought perhaps it was a duff engine mount? The guy reckons it's been like it for a couple of months.
http://www.freeads.co.uk/uk/motors/cars ... miles/view
any ideas?
cheers.
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
It could be a worn bottom engine mount. Is there any engine rock when it ticks over?
Check for a damaged front tyre. A bulge in the tread could cause a similar shimmy.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
also, very likely inner driveshaft 'tri ax' joint :)
mainly manifests itself in third under load
second hand driveshaft and you'll be right
had exactly the same problem with a ZX.,,
John
x 94
Unread post by citronut »
check rear tyres far buldges also,
it dose look a very clean car otherwise,
regards malcolm
