Hi , Iam about to change the coolant in my 1997 Xantia diesel with a/c . Is this an straightforward task . How much coolant will I need ? Which is the best antifreeze for my Xantia .
Cheers Terry .
Xantia - new coolant
JohnD
- x 72
Re: Xantia - new coolant
Just as important to its ability to stop the coolant freezing, is the ability to stop corrosion damaging your engine and radiator. A 20% mix would probably be OK for a mild winter, but for corrosion purposes, a 50% mix is better. Find the capacity of your cooling system (around 8ltrs if I remember rightly) and plan to use half that amount as antifreeze.froggy wrote: How much coolant will I need ? .
Some radiators conveniently have a tap at the bottom, but if not, it'll be necessary to remove the bottom hose. Empty then flush through with water. Refill with half a litre of antifreeze, followed by half a litre of water. (I always use water from a dehumidifier.) Continue until the header tank is full. Open all bleed valves and allow the engine to tick over until all the air is expelled. It's important not to allow any airlocks to remain.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
froggy
- (Donor 2026)
- x 4
Thanks Guys
Cheers Terry
Cheers Terry
froggy
- (Donor 2026)
- x 4
thanks for the imfo . but where will I buy the Mercedes Antifreeze ?
cheers Terry
cheers Terry
JohnD
- x 72
- x 5672
the_weaver
- x 5672
Looks that way - I wondered if it might be in reference to anti-sludging properties but apparently not.the_weaver wrote:Antigel - is that just the French word for antifreeze or is it something different?
Paul
