Which radio?
rabenson
Which radio?
Unread post by rabenson »
I have a late pre-facelift C5 (2004 04) and am wanting to fit an Ipod adapter. trawling through posts, it seems that the Connects2 range will do the job. However, there are two listed on their website for my car - one of the Clarion radio and one for the Blaupunkt radio. Unfortunately I'm not with my car at the moment so can't pull the unit to look. Does anyone know which it's liable to be?
The installed unit has a single cd slot and the associated display does not include satnav, if that's relevant.
Cheers,
Ron
2007 C6 2,7 HDI exclusive 95k
2004 C5 VTR HDI 103k
rabenson
Having looked at a few units on Ebay, I've come to the conclusion that it's probably a Clarion unit. Fingers crossed! :)
timborob
Unread post by timborob »
I have a late 03 reg which is a Clarion Unit
so i would go with that choice too
Good Luck and hope its the right choice for you
Regards
Tim
03 Citroen C5 2.0 110 HDI VTR Mauritius Blue 109K
rabenson
Great - thanks Tim, much appreciated!
Kit ordered, should be here next week
Ron
rabenson
kit arrived - fitted in 15 mins including tidying up and tying the wires (dead easy!!). works fine! Well chuffed :D :D :D
Julz
Unread post by Julz »
is the radio easy to remove? my CD appears to have packed up so I was going to have a quick look inside
1999 306 1.9TDi meridian estate (written off)
2001 C5 2.0HDI LX estate
rabenson
Yes, just slide a thin screwdriver or knife under the bottom edge of the triangular-ish trim panel surrounding the switch on the right side of the radio (central locking switch) and lever the panel out. (it is hinged to the top of the radio and will lift out and up).
Just below the hinge is a screw (one of the star type things so beloved of citroen....) Remove this screw.
Do the same with trim panel on the left side of the radio and remove the screw from there. The radio will now pull out ok!
Cheers,
Ron
Julz
rabenson wrote:Yes, just slide a thin screwdriver or knife under the bottom edge of the triangular-ish trim panel surrounding the switch on the right side of the radio (central locking switch) and lever the panel out. (it is hinged to the top of the radio and will lift out and up).
Cheers,
Ron
Many thanks, worked a treat. Had a quick look inside and the disc isn't spinning so will have to have a more detailed fiddle some time
Andy F
x 8
Unread post by Andy F »
I have been having similar thoughts to putting in an adapter. My C5 is a 2001 with a Clarion head unit. All the adapters online say its for an RD3 unit, which looks the same as mine but mine says RD2 on the top. I dont suppose you remember seeing what model yours was, as if it is a RD2 and it works i'll be getting one too! the other code for mine says 2295B(H) whatever that means...
Cheers for now
1999 Citroen Xantia 2.0 HDi 110 Estate
2001 Citroen Xantia 2.0 HDi 110 LX
1999 Citroen Xsara Picasso 2.0 HDi 90
1983 T25 VW camper
1994 Mini 1275 35th Anniversary Edition - sold
2007 C8 2.0 HDi 136 Exclusive - sold
Previous AXs
1987 11RE
1987 11TRE
1995 Dimension
rabenson
Andy F wrote:Hi,
Cheers for now
You're right - I don't. :D
I'll have a look at the weekend and let you know!
Ron
