Hi everyone,
Xantia 2.0 16v 1999 - I need to know what the name of the following part is and whether I need to get it replaced.
Imagine standing in front of the car looking down at the engine. At the front of the engine block and towards the right hand corner there is a rubber hose that comes out of the top of the block. The hose leads towards a circular plastic filter looking part. The hose then carries on towards the throttle body. Question is, what's the circular plastic filter looking part? I've had the car since September '09 and have noticed that there's an oil residue on the outside of it. My concern is if it's supposed to be some sort of filtration device and it's leaking then it may be blocked.
Any ideas would be appreciated.
Thanks,
Marc.
Part name required - Xantia Engine
- x 94
MikeT
- x 232
XantiaFT
MikeT - that makes sense...definitely not charcoal filter (I know where that is)...and it's definitely not being entered into a show unless there's a category for 'best example to put an aspiring Citroen owner off' award!
As long as it's not vital and not requiring replacement...that'll do. Thanks for your help.
