xantia tailgate electrics
wotwot
(Donor 2021)
x 4
Unread post by wotwot »
Is there a mercury switch in the tailgate as mines taken to only working the lights on the tailgate when its half open (num plate lights,reversing lights,stoplight,) :( ,the wiper motor still works :?.
Xaccers
x 188
Unread post by Xaccers »
I believe its a rolling ball switch, which gets rusty and stops the ball moving.
Can be replaced with a tilt swith from maplins.
Can't remember how to get to the old swith, but its been posted about before.
DIY sphere tool
wotwot
(Donor 2021)
x 4
Thanks for that any idea what heading it may have been under,when i searched "rolling ball switch" nothing came up.
x 1240
Unread post by Peter.N. »
You will probably find you have a break in the wires going from the body to the tailgate, if you are loosing several lights its probably an earth.
wotwot
(Donor 2021)
x 4
thanks Peter no broken wires fortunately but a bad connection somewhere,not sure which one but pulled them all apart and back together and all my lights are back on :D .I will get in there with some electric spray when I get some and check them all out.
