Hi Forum
I'm about to change the aircon compressor on my Citroen Xantia. I seem to remember hearing that i should change the dryer at the same time??
My general question is: What should I change aswell as the compressor?
Thanks very much
Larry
Replacing Xantia Harisson compressor
lazza
(1996 Citroen Xantia 1.9TD LX with aircon)
Living in exile in Spain
Running on 100% veggie in summer
vanny
lazza
HI thanks for your reply
when you say add oil to the system.. do you mean i need to directly put oil in the compressor??
i thought that when they refill the system with gas, that they automatically put in a percentage of oil.
can anyone enlighten me?
thanks
Larry
thanks
Larry
- x 1481
The oil in an A/C system is in one of 3 states:
a) dissolved in liquid refridgerant
b) being blown along by gaseous refidgerent
c) sitting in the sump of the compressor
The oil in the compressor sump acts as a reservoir.
If an A/C system looses gas over a period of several years due to porosity, or the compressor shaft seal, very little oil is lost, so a standard re-gas does not include any oil. If any component is replaced, a new component is supplied dry, so an amount of oil corresponding to the residue in the removed component is added.
If there is a large leak that causes oil loss, the operator just has to guess how much oil to add (and sometimes what sort!).
If a used compressor is fitted, it is also a guess as to how much oil is in it (some have a drain plug, but even that seldom allows all the oil out).
In situations like this you need luck, or an experienced operator to guess the amount of oil to add.
lazza
Thanks very much for your reply
I am replacing it with a 2nd hand compressor- which I presume still has oil in. To be on the safe side:
How much oil should I add?
How and where do I add it?
Many thanks
Larry
Many thanks
Larry
MikeT
- x 232
Hi Larry,
Sorry I can't be of more help as I have little to no experience of A/C systems other than common knowledge.
What I can say is that compressor came from a filled system (on removal I accidentally punctured the condensor and the gas leaked out) and in my care, have not noticed any oil seepage from the compressor so, hopefully, there's still the right amount in it.
