xantia cable entry header tank cap
dudarus1
just bought a xantia td and have a few issues the header tank cap seems to hiss after a long run do u think headgasket or just the cap. also want to put an amp and 6 x 9s but cant figure out how to get the power cable through the bulkhead cant see any gromits. thanks
citroenxm
- Fallen Hero
- x 70
Have you got Air Con???
If not theres an area were the Air Con evaporator drain pipe would go low down in the bulkhead, twards the rear of the gearbox diff.. The sound deadeneing is cut out to pull away, but I connot remember if the metal is still in place behind it...
Otherwise its a very well constructed bulkhead and accessinto the cabin directly for extra wires is quite difficult..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
andmcit
- x 30
Try an alternative cap before panicking! These do run at quite a pressure
so even something like the seal under the cap may be a bit unseated.
You'll have to remove the driver's wing and access is through the door
pillar into the main loom feed behind the dash just behind the fuse box
- yes, that awkward! Don't go anywhere remotely near the heater matrix
feeds as they'll break so much as look at them and then you'll be b****red...
my be worth looking at the power feeds running off the ignition switch?
Andrew
Andrew
