V6 aux belt crank pulley
Stempy
Unread post by Stempy »
The pulley is slipping and needs replacing, is it just held on by the four M8 bolts or do I need to remove the centre bolt?
Lexia ponce
x 8390
Nope, I'm happy to say just the four little bolts Stempy :D
A nice, easy job!
Stempy
CitroJim wrote: A nice, easy job!
No such thing on a Citroen...........
Lexia ponce
x 8390
That one is, once you've released the auxillary belt tensioner and removed the RH mudshield that is!
The former is easy enough as long as you have the requisite spanners and the latter is easy if the bolts aren't seized; they so often are unless regularly disassembled and greased well..
Stempy
So I was right then, seized bolts :roll: :lol:
Lexia ponce
