xantia ride height
wotwot
- (Donor 2021)
- x 4
xantia ride height
Hello again did a search but could'nt find anything,can anyone tell me or give me a link to the ride heights for a 96 deisel xantia estate,I thought the citroen ride heights might have been stickied.and if anyone wonders why I need it check out my very first posting on my xantia,issue which is now resolved
- x 8391
Ride height by a rule of thumb (or finger
) can be checked thus:
At the front you should be able to insert three fingers between the top of the tyre and the wheelarch lip. At the rear one finger should fit.
That assumes average fingers
Ride height is critical to good ride comfort.
wotwot
- (Donor 2021)
- x 4
addo
- Sara Watson's Stalker
- x 95
Old-Guy
- x 24
Details of measuring ride height on my web page. Both a quick method and the official way.[/url]
- x 94
you need to make 200% sure all the turrets at both front and rear H/C's are fully free, before you adjust anything,
you cant check there free movement properly without removeing them from the car,
its not the H/C itself that seizes, its the two turrets attatched to the H/C mountting brackets that seize,
regards malcolm
regards malcolm
red_dwarfers
- x 58
wotwot
- (Donor 2021)
- x 4
Thanks all for the info,managed to get mine to sit front 655 back 595.
much smoother ride now,still lots more to do N/S lower ball joint, discs and pads front, wheel alignment (tyres badly worn both on inside edge)and tyres,alternator belt,cambelt & tensioner set should be delivered this week £45.
Been shopping around for prices bit of a hit and miss game, found front discs and pads for £44 free delivery as well is that a good price.ITS ONLY MONEY!!!
