Xantia steering rack gaiter
Martin Beevers
Unread post by Martin Beevers »
Hi all,
I will be doing my steering rack gaiter this week before my MOT at the end of the month.
Unfortunately it's the near side I have to do, so I know I'm in for a bit of a game. I made sure I got a pattern part made of stretchy rubber so I stand a chance of getting it over the spigot.
My question is- What grease should I be using to pack inside the gaiter and how much to put in?
Also any useful tips would be appreciated:)
95 Xantia 1.9TD SX - Now sold
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
hi Martin, I can't speak for the xantia, but when I did a 605 NS once, I put a nylock nut on the spigot, and then cut away a fair bit of the spigot that wasn't really needed.. finally I greased the nut, and the gaiter pulled over quite easily.. can't remember where I got that tip, but maybe worth passing on..
John
x 94
Unread post by citronut »
John
the spigot is not threaded externaly but internaly, and as its a steering component i would advise not citting anything down,
the rubber gaitor dose go over the spigot with loads of PERCY WHAT SIT,
just be aware both end are slightly diferent diamiter's, and if you think you have beat the gaitor into submition, but it is on the wrong way round, you will have a job makeing the wrong end stay put on the rack body neck,
regards malcolm
jgra1
(Donor 2021)
x 36
K malcolm thanks for that...
Martin Beevers
Any idea what grease I should use?
the_weaver
Unread post by the_weaver »
I've got the nearside steering rack gaiter to do on my ZX soon. Sounds like it's a difficult job on the Xantia. Is the ZX difficult too?
Paul
x 94
sorry to say Paul but i just looked at ZX steering on service citroen, and yep it dose have the external steering ram like the XANT has,
so its a very similar job,
just make sure you get a rubber after market gaitor, not the OE thermoplastic type as they dont streach at all,
the only way to fit that type is remove and strip the rack completly,
regards malcolm
the_weaver
Malcolm
Thanks for the info. My car hasn't got power steering. Does that mean I'm ok? Is the external ram part of the power steering?
Paul
KennyW
x 165
Unread post by KennyW »
Hi Martin,
If you are stuck I have a spare rack with new gaiter fitted minus the steering pinion it was leaking (1.9TD but 98) I can't think of any differences. Other members may know otherwise. Rack's free if you are interested we could use the the member's relay system.
But I recall when changing mine, It was fairly easy to remove the track rod when old one is off and put new one on.
Kenny
C3 1.4 petrol (SWMBO)
x 94
yes Paul you are in luck, it is only the power steering version that has this problem,
regards malcolm
Martin Beevers
Thanks Kenny,
With MOT looming I reckon I will manage to get this gaiter done in time. I will keep your offer in mind if I find any more issues along the way.
Will normal grease be OK to pack the gaiter with?
the_weaver
Thanks Malcolm, that's a relief.
Paul
Martin Beevers
Job done,
Was a bit tricky to get the new gaiter over the spigot... I left the nut on the end to stop the threads doing any damage, greased the whole thing, stretched it to a point I thought it would split at any second. I used a ring spanner to tease it over the spigot bit by bit.
