Got in the car this morning, all fine. Got to work and the car would not lock??
Thought it was the remote, so tried to lock on the key, and only the drivers door locks.. Central locking obviously ker broken.
Any obvious places to check, things to look for when I get back.
(As an aside, I cant even lock one of the rear doors. The locking button will not depress, door closed)
As always, any help or ideas would be appreciated.
- Dave -
Xantia S1 - Central Locking not working
gadgetgricey
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
gadgetgricey
Got in the car to go home tonight, and no power, nothing???
Had a look under the bonnet and found the culprit.
Lead has cracked and had come off totally. Put it back on, but dont now for how long. Easy job to replace??.
- Dave -
- Dave -
Xaccers
- x 185
similar happened to one of mine, used bolt cutters to chop the old ring off and got a replacement from a car audio place to take all the wires.
Something like
Or if you want to be funky
an alternative is to remove the broken outer half of the ring, and use the bolt to fit a new ring.
Something like this
So use the old ring's bolt through where the new ring would clamp onto the feed.
Something like
Something like this
DIY sphere tool
DIY sphere tool
