Aircon Condenser
chelseaalan22
Aircon Condenser
Unread post by chelseaalan22 »
I tried to get my aircon regassed but when the system was pressure tested we heard a 'Hissing' sound.
Looking from above the sound comes from the N/S bottom of the rad.By putting my hand under the rad in the corner and 'Jiggling'it about the sound gets louder then quieter.The guy said it maybe a hole in the condenser or mybe a loose nut at the join. However I cannot see how to access it to take a gander. I have looked in the maual and yes you guessd it it says take to aircon specialist which I cannot afford.
Could anyone please tell me hoe to get access to the condenser please???
Many thanks
chealseaalan
2002 Xsara 2.0 HDI sx 110hp
fridgedoc
Unread post by fridgedoc »
Hi Alan
even if you get the condenser removed from the vehicle it's going to cost in the region of £300 plus a receiver dryer (£50 to £100) plus the system will need evacuating and then recharging, depending on what refrigerant it is running on, I have been retired for a few years now so my pricing could be out.
Sorry for the bad news
Bonne Chance
Stephen
LHD Xantia 1994 (deceased)
LHD Xantia 1995 Berline
Xaccers
x 188
Unread post by Xaccers »
dryers can be picked up for about £18
condenser is about £115 from gsf.
would be worth taking it to a specialist to confirm where the leak is.
DIY sphere tool
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
On Xsaras, just like 306's useually go on the pipe that runs across the cross member, the Metal clips trap moisture under the rubber and corrode the pipes..
Condensers are cheaper then they used to be, try www.autokool.co.uk they may be cheaper then GSF..
Rgds
Paul
A very sad...
1994 XM 2.1 d auto
fridgedoc
condensers
Hi All
Well I'll sh1t in my hat and punch it!!!!!!!!!!!!!
Have those prices dropped, I always thought they where a rip off both the driers and condensers, I felt terrible sometimes when we quoted for a condenser change, prices are a lot more sensible now, though I wonder what price they are here in France "Double" the price I bet.
Bonne Chance
Stephen
chelseaalan22
condenser
Thanks Guys.
But I need to get access to it to see the problem.Is this from underneath?
Chelseaalan
citroenxm
Fallen Hero
x 70
Condenser is in FRONT of the cooling radiator
Dryer is to the left on the off side inner wing the likly pipe to be leaking will be across the lower cross member... which is viewable from underneath...
Paul
A very sad...
1994 XM 2.1 d auto
chelseaalan22
condenser
Many thanks Citroenxm,
I shall give it a look at the weekend.
Chelseaalan
chelseaalan22
Air Con Condenser
Guys,
I have looked for the condenser but cannot see it.Taking off the front grill I can see there are 2 pipes,these run from the off side to the near side and bend and return,Moving the fan I can see they disapear into the wing below thw offsde headlight I presume to th dryer.But where the hell is the condenser?
Any ideas this is driving me nuts.
Many thanks
Alan
xsara SX HDI 110hp. 2002
citroenxm
Fallen Hero
x 70
Condenser is sandwich'd between the Fans and Water cooling radiator...
Paul
A very sad...
1994 XM 2.1 d auto
chelseaalan22
Xsara Air Con
Thanks Paul,
I have taken the fan out and standing in front of the car I can see the rad clearly. To the right hand side there is a plastic panel from top to bottom in the middle it has the elecrical conections for the fan ( only one fan) to the right of this and in line with the rad is a smaller rad which I thought was part of the intercooler or am I just being stupid???????The pipes rin under and along the rad and this smaller rad and do a U bend run back and disappear under the plastic in to the O/S inner wing area which I presume is where the dryer is located.
Please help!!!!!
Cheers
Alan
Xsara 2002 2.0HDI sx
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Alan:
http://www.mister-auto.com/catalogue/fr ... .3014.html
Should look something like the picture!
