Hello,
Advice sought please on how to rectify this fault now showing on digital display - the tire in question is fully inflated.
Many thanks,
John.
C5 Exclusive Tire Pressure Fault
johnway
My chariots : 2002 Pug 406 110 HDI Executive Estate 138K
1995 Citroen AX 1.0 Debut 26K
I Blame it all on my Dad!! (Sadly had to give up driving & his 2nd BX) but Mum still has a C1.
jimleshed
Without a few more clues I'd guess that the sender unit in the wheel is on the way out. Your only options are to replace it or ignore it. Somewhere on here there is a thread with some of the different types of sender identified.
You can buy a replacement off Ebay, but you need some special kit (not a lexia) to fit it.
With a Lexia you can get it to ignore all the senders, so you dont get the warning - which is another option.
Jim Le Shed
Citroen C5 2.2 HDI Exclusive
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
Citroen GS (lots of other Cars and Bikes too!!)
Mazda RX8 231PS
Past history...
Mazda MX5
Renault Lagunas (3)
Peugeot 405, 205
Citroen CX's (5)
- x 1940
The TPMS (tyre pressure monitoring system) valve might be faulty. You need a Lexia to check this and also a TPMS exciter to resynchronise the valves to the car. You might be lucky and find it just needs resynchronising but I doubt it.
Many members here have a Lexia but AFAIK no-one has an exciter, although one member managed to borrow one. I used my Lexia to turn the TPMS option off to avoid the nag message.
jimleshed
