zx starter motor
froggy
(Donor 2026)
x 4
zx starter motor
Unread post by froggy »
hi , my starter motor on my zx , has " packed - up ! I need to move it from my parents house to my home . Is there an easy way of starting it ?
When I get it home , is it a simple task to replace it ?
many thanks , Froggy .
Xantia 1997, Temptation , 120773.
zx 1995 , 109346
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Its it a Petrol or DERV?
A Derv is quite easy asits on the front of the engine, as for TU 1400's its on the rear of the block below the inlet.. only 3 bolts though hold them on..
If its a DERV with no cat then you could tow start it.. I doubt you'd bump it due to higher compression.. however, a Petrol, people dont reccomend it for the sake of the Cat.. But Ive never experianced it..
Paul
A very sad...
1994 XM 2.1 d auto
spider
x 77
Unread post by spider »
It would (probably) be ok as a bump start in a petrol cat engine as a one-off, although there is a risk of damage to the cat with unburnt fuel, although as far as I know it would be no more of a risk than someone driving with a misfire (dead plug or damaged coil pack) for a few miles.
But as above, there's a risk. You could chance it I've never actually known one to fail, but there's a first time...
What's actually wrong with it ? , I assume you have tried gently persuading it with a block of wood ?
Andy.
x 1240
Unread post by Peter.N. »
Is the starter actually dead or could it be the solonoid? Try shorting the two large terminals on the starter solonoid together with a large and preferably disposable screwdriver. Otherwise it certainly won't do any harm to tow it, diesel cats dont suffer like petrol ones.
spider
x 77
Just a quick note: If you are going to do the 'large screwdriver' trick
DOUBLE CHECK it is not in gear :!: , its not funny being ran over by your own car. :wink:
Andy.
x 94
Unread post by citronut »
i dont recomend bump startting a diesel as you risck shattering the clutch disc,
regards malcolm
