c5 alarm
wright
c5 alarm
Unread post by wright »
does anybody know where the siren is fitted on a 02 c5, my father is selling his c5 so i've got the alarm, i fitted it to my car and turned it on with the lexia, all seems fine but there is no sound.
x 1044
Unread post by wheeler »
What do you mean by you fitted the alarm ? The siren is behind the osr wheelarch on an estate, cant remember if its the same on a saloon.
wright
i took out the alarm box from behind the fuse box and the ultrasonic sensors that were connected into it,
i fitted them into my car, then installed them with the lexia, a scan revealed no faults but when i go into the actuator tests i hear no sound when i select the siren.
wright
found it behind the rear passenger wheel, swapped them over and its working fine, mine is a hatchback
