Harrison A/C Compressor seals
lazza
Unread post by lazza »
HI
I have managed to evacuate all the gas in the system, there didnt seem to be hardly any pressure anyway.
It seems quite easy to get the compressor off- Aux drive belt and four bolts, plus inlet and outlet of A/C system .. i think
Does anyone know where I could get hold of the seals to repair the aircon?
the main leak i think is in the middle of the compressor housing where the halves meet.
Larry
(1996 Citroen Xantia 1.9TD LX with aircon)
Living in exile in Spain
Running on 100% veggie in summer
x 1463
Unread post by xantia_v6 »
I have bought compressor seal kits for other vehicles from http://www.polar-aircon.co.uk/ Their website is a bit clunky, so you might have to give them a call...
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Larry
Thats an interesting discovery you have there.
I fitted a system from a T reg HDi Xantia to my L reg 1994 TD Xantia.. The system worked perfectly in the HDi, but after fitting it to my TD, with a new set of seals, I then discovered when I tightend up the Compressor mounting bolts the body Leaked as you found... but when I slacked them it stopped.
Ive aquired a solid body compressor now to swap over..
Let me/us know how you get on with the compressor.
Regards
Paul
A very sad...
1994 XM 2.1 d auto
