Topping LHM..
ipan8894
Topping LHM..
Unread post by ipan8894 »
I like to know the correct way to top up LHM liquid for Xantia.
1994 Xantia 2.0i Silver/Black
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Ipan, start car, then suspension on it's highest setting. whilt the car is running, add LHM to reservoir until orange marker floats to the middle of sight glass..
John
ipan8894
haha, thanks a lot. Just got the car from my parents. :lol:
Old-Guy
x 24
Unread post by Old-Guy »
To check and fill the hydraulic reservoir, the engine must be running.
Move the suspension height control lever to HIGH (rear-most position) and wait for the supension to rise fully.
The orange 'mushroom' indicator should now be between the two lines on the sight glass (sometimes it gets stuck and needs a gentle tap to get it to in register properly).
Topping-up is a lot easier from a small plastic jug (e.g. ½L) half-full of LHM than trying to pour from a 1L bottle or a 5L can. Top up slowly until the indicator is about half-way between the two marks.
If you over-fill, the surplus just leaks out of the top of the reservoir making a mess but doesn't harm the hydraulic system. The same thing happens if you fill to the top mark and indulge in some spirited cornering. :wink:
Remember to return the height control to NORMAL before driving off! :shock:
Too slow!!!
ipan8894
thanks, thats explain why there are some LHM dripping from under the body.. i just slightly overfilled :lol:
