I've a P reg 806 2.0l Petrol, it's generally run fine for the year or so I've had it, but just lately the engine appears to cut out for no reason at random intervals. I've changed spark plugs and fuel filter, it can go for miles with no problem and then suddenly starts cutting out again. Generally after misbehaving for a few minutes it seems fine again.
Most annoying as I can not consistently replicate the fault.
The vehicle had the immobilizer removed a couple of years ago
Wonder if there might be some obvious problem??
806 Engine stopping
james5353
806 Engine stopping
spider
- x 77
Not off hand no, (fuel filter was the obvious thing but you've changed that)
It's worth having it plugged into a Lexia / Diag to see if any faults have been stored that may give a clue as to the cause.
I'm assuming it will have a fault code stored as its intermittent it would be very difficult to diagnose otherwise...
Andy.
james5353
- x 8448
James, welcome to the forum
I have (very) intermittently had this on one of my 2.0i Activas. Same engine I believe, bar the turbo...
The engine would cut, normally at 70mph,and then almost immediately restart. One clue was that when it happened all the dials on the dash fell to zero and the warning lights briefly came on.
I've not 100% solved it but since swapping the double injection relay it seems to have gone away. The double injection relay is the big one that sits next to the engine ECU and powers the ECU, injectors and fuel pump. Nowadays I always keep a spare double injection relay in the glove box.
Next time it happens, listen for the fuel pump stopping briefly.
It's almost certainly electrical.
Another possibility is an intermittent in the ignition switch.
james5353
