Caravan towing with Hydractive Suspension
steve101
I have a 09 C5 saloon, manual with Hydractive suspension. Does anyone know what it's like towing a caravan with one?
Chris570
- x 36
Trainman
- (Donor 2018)
- x 43
Steve,
With my old C5 I pulled a car transporter and Honda Civic from Preston to Warrington and back withno problem whatsoever. My old man pulls his caravan with a 51 plate 2.0 est with no trouble, in fact he's up in scotland at the moment
Both had/have Hydroactive suspension
Steve
http://c6owners.org/index.php
steve101
h2ocooler
It will just self level no problems at all, I towed a FULLY loaded caravan through france at 80mph (no restrictions over there) no drama at all, most of the time I didnt know it was on there.
Rob
Rob
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
steve101
JohnD
- x 72
I've pulled my Bailey Pageant Imperial with my C5 down to southern Spain every winter since I got it in 2005. It makes for an effortless tow and depending on towing speed, I get between 25 and 30mpg. Suspension pumps up level and stays there without any pitching fore and aft.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
steve101
Can you tell me what the MTPLM of you caravan is and what percentage it is of your cars' kerb weight?JohnD wrote:I've pulled my Bailey Pageant Imperial with my C5 down to southern Spain every winter since I got it in 2005. It makes for an effortless tow and depending on towing speed, I get between 25 and 30mpg. Suspension pumps up level and stays there without any pitching fore and aft.
JohnD
- x 72
Kerb weight is 1532 and MTPLM is 1200 so I'm running at around 80% - but since we go for four months, I'm always heavily ladened. Roof rack, bikes etc.steve101 wrote:
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
skinhead
I tow a Bailey 1360kg with my 2.2C5 mk1 & find towing with the hydroactive suspension perfect when set to sport as it keep the van level so very little effect from the passing of large vehicles & being able to raise & lower the t car makes hitchin up a doddle.I got an average of 28mpg on an extended tour down to Dubrovnic under all road conditionssteve101 wrote:Thanks for the replies. I used to have a Bailey 4 berth which I towed with a Nissan Primera 2.2di estate. Nice car but crap engine. It sounded like a tractor under the slightest load. I was wondering how the suspension in my C5 would react to the nose weight of the caravan.
Max noseweight allowance for car is 75kg
skinhead
hobblerian
WOW thats a surprise to me the C5 only having 75kg weight limit on the towbar. On my XM saloon its 110kg.
Its always possible to change the nose weight of a caravan by how you load it anyhow. So if it has a naturally heavy nose you can load more at the rear to balance it out.
Previous 90H S1 XM 2.1td SD Manual
Current 97P S2 XM 2.1td VSX Manual
steve101
skinhead
I own a series 1 C5 not sure if later models are the same 75kg n/w allowancehobblerian wrote:WOW thats a surprise to me the C5 only having 75kg weight limit on the towbar. On my XM saloon its 110kg.
but loading to the rear can cause instability by causing a seesaw effect.loading must be kept low over the axle or just to the rear of it. I stronly suggest you do research before buying car or van check out this thread
http://www.caravantalk.org.uk/topic/344 ... -findings/
steve101
