Hi all.
Has anyone ever reprogrammed a bsi unit and if so
any pointers/tips or advice welcomed.
Also is the interface used the same for planet as lexia?
THANKS...BERLINGO BOB
[DRIVES A PARTNER REALLY]
OFF THE SUBJECT REALLY BUT ENGLAND PLAYED THEIR HEARTS OUT AGAINST SLOVENIA !!!!!!
reprogramme bsi unit
dieselnutjob
- x 1044
Is this a mk1 or 2 ?
Are you fitting the BSI you had 'virginised' ?
You will need all the cars key's & the 4 digit transponder code before you start.
Is there a BSI still fitted to the car & can you get dialogue from it with planet ? if so you want to go into the customer options, BSI configuration & ECU's present menus & print out/note down all the settings.
Fit the new BSI then go into the learning menu & carry out the 'BSI initialisation' procedure, it will gude you through it & then you need to program the keys during this procedure. You will then need to go into the cust options, BSI config & ECU's present menus & enter all the info that you printed out/noted down earlier. If you can get acces to the original BSI configurations then it will be a bit more akward & time consuming.
Out of curiosity whats wrong with the BSI ? water ingress ?
