C5 2.2 HDI Auto Head Gasket Change
acrowot
Going to change Head Gasket shortly, this engine is not covered in the BOL are there any pitfalls to look out for, is it any more difficult than the 1.9 td, I have done a few of them. Any help gratefully received.
C5 HDI 110 SX 122000 ESTATE
C5 HDI 2.2 2003 EXCLUSIVE ESTATE 151000 MILES
- x 1056
acrowot
Thanks for your reply wheeler, do they have to come out to do a gasket change, I will be trying to remove them but do I have to do just for the gasket or only for a head skim?. This head was removed by a so called professional garage about 2 years ago as a result of a cambelt snap before it belonged to me, I noticed the injectors were leaking a few months ago and I was able to stop the leaks by tightening the nuts which were quite loose so maybe they will come out, fingers crossed.wheeler wrote:The biggest pitfall i can think of is getting the injectors out without wrecking the head. They can be a total nightmare & loads of 2.2 engines have been written of due to this. Some of these injectors wont even budge with a slide hammer attatched to them.
- x 1056
acrowot
I thought the injectors were held down with 1 nut but that is the injectors on the 2.0 HDI, the 2.2 injectors are held down with 2 cap heads per injector I think 7mm. It does look like the cam cover will come off without removing the injectors but the inlet manifold may be a problem. Is this engine 16 or 8 valve engine, the cam cover seems quite small for a 16 valve. I have also ordered a Chinese Lexia 3 today as the engine has other problems, this should be fun.wheeler wrote:If I remember right I dont think you can get the head off without removing injectors, The studs hold the camcover down.
h2ocooler
The 2.2 is a 16 valve, I had to change the fire seal and washer on one of my injectors, it did come out easy (the cap bolts are 7mm, I use the tool for escort brake calipers i think)
Rob
Rob
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
cachaciero
- x 9
I have read a lot about 2.2 injectors being difficult to remove, some where on this list I did see a recommendation to soak them overnight in cokacola.
One thing I read somewhere else apparently on the Mercedes A series diesels the injectors can be a pig to get out probably for the same reasons, the solution there was to apply paint stripper around the injector allow it to soak in overnight and then the injectors would come out easily.
Don't know if this will work or not but I pass it on on the basis that one day somebody might be desperate enough to try it, if you do please let us know if it works
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
KP
- x 27
