Hi, The pump started life as an IDI but to look at it it looks just like a di pump from a Kia sedona + rover 200 ,
I've built this pump to a similar internal spec to the mechanically operated VAG TDi 115bhp pumps that I build , so has a much steeper camplate , larger distributor and head , governor from a normally aspirated to give extra 500rpm , different parts to change advance curve , plus a number of other modifications making it unique to this engine with working pressure above 300 Barr
Injectors are from a direct injection turbo engine , I searched through many types of injectors , problem being the ones that fit best were only single stage ( meaning more stress and sounding like an old transit Di )
I then found some injectors with 5 hole nozzles that worked two stage 220-300 Barr , I had these machined so they'd fit into the HDi
Engine to start with is a DW10 , 2.0 Litre but thinking to fitting a 2.2HDi ?? at a later date
starter bolts onto one of my adaptor plates at the front of the engine as it would be on the PSA gearbox
The VW TDi engines that the bus guys use aren't common rail , they have a Bosch VE37 pump that's operated by ECU same idea as the last 406 2.1 td's ( Lucas )
- A lot using Land Rover TDi pumps on VAG TDi's but not the best LOL!!
