can anyone use a lexia
wright
Unread post by wright »
i've looked at old threads looking for an answer to these question, others have asked but no conclusive answers
is the rpo number important when using a lexia, it seems to start up regardless of what number i put in.
someone said it is on a sticker inside the door, there are a few numbers on the sticker, is it just numbers or could it contain letters?
h2ocooler
Unread post by h2ocooler »
Its just numbers, its the 5 figure one.
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
wright
thanks
is it in any way important to put the correct no in?
h2ocooler
I believe it is, the number tells the Lexia what build/model/options are on the car, as far as i know you can put the VIN number in too.
Rob
miked
x 6
Unread post by miked »
4 digits on or before 24th March 2004 (RP 9999), 5 digits on or after 25th March (RP 10000)
h2ocooler
Mine is an 03 plate and the RPO number is a 5 digit, it is located at the front of the drivers door shut on the A post below the tyre pressure sticker.
I think peugeot's have a 4 figure number on the suspension turret under the bonnet.
Rob
