Clutch does not begin to operate until the pedal is half way down.
Could there be air in the system?
I can't find the fluid resevoir, can it be topped up and bled, or is the system sealed?
Espace 2000 Clutch
Mambyj
daxter
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Mambyj</i>
daxter
JackDaniels
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by daxter</i>
Hello, I've got exactly the same problem with my clutch, can you tell me how much did you pay to get it repaired!
Since my renault dealer cannot do my car before 2 weeks, I will replace the hydraulic mechanism by myself, has anybody ever done this?
Any tips or comments would be great, thanks.
daxter, any problems doing this?? I guess I may have a similar problem, 1998 Espace, I would describe the problem as pedal stiff, not returning fully. If I release the short cable on the operating arm and push the linkage backwards (into the slave cylinder) and then replace the short cable, the clutch is o.k. again for a week or two.
Mambyj
Never had my clutch done yet as it works ok, the only problem is that the clutch does not return fully every time. The part costs £110 + vat, the labour time is about 4 hours, so I would think a main dealer would charge about £300 to £400. New part is an improvement, ie. is not sealed, and can be bled.
Nav
Mike Pring
Hello
I have a 96 2,2 diesel espace with the described clutch pedal problem. Has anyone done any mods on this such as fitting a substitute slave cyl with a bleed nipple?? Does anyone know where the air gets in, master or slave cyl? Suggestions and ideas to get round this problem without paying Renault prices would be appreciated
