Xantia electric window
gotanothergrot
Unread post by gotanothergrot »
Hi Guys (and gals)
Unbelievably I have had little go wrong with the xantia since I last posted. Great car now becoming a bit of a workhorse filling her up with wood ect, was going to put some fence panel directly onto the roof today but decided against.
However divers door window has stopped 1/3 way down and I need to get the thing closed for obvious reasons. Its not a fuse as the passenger side is OK.
when I get the door panel off will I be able to turn the motor to wind glass up? What could of caused the failure.
Xantia Hdi 2.0 "w"
ta
x 5672
I would guess at a failed switch or a broken wire in the loom into the door.
gotanothergrot
When I get a longer T30 tomorrow Ill see whats behind the panel. :D
gotanothergrot
sorted. Loose connection on the motor :)
I wander what that would have cost in the garage.
