Wheel sizes
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 232
Wheel sizes
Does anyone know their wheel sizes etc? I don't suppose there's the slightest chance a set of Pug 4007 alloys would fit my Xantia?
- falling-out-with-my-car
- My Cars: Citroen C5 Aircross 8 speed Automatic, Flair Model with far to many toys and nice comfy armchair like leather seats. ha ha Ive just had a conversation with the car. setting everything up verbally
- x 24
won't all this wheel changing effect the read out on the speedo?
regards Nigel.
regards Nigel.
No, not if you retain the correct existing radius of the whole wheel by
compensating with the sidewall section of tyre by raising/dropping a size
getting the measure right again. Or you have to live with the known
%age difference for the sake of aesthetics and make a running mental
calculation of the true speed whenever a safety camera or plod approach!
Andrew
Andrew
- My Cars: 07 Citroen C6 V6 HDi Exclusive - Red
07 Citroen C5 HDi VTR - Red
09 Citroen C3 1.4i VTR - Silver
01 Citroen Saxo 1.1i Forte - Mango Orange
93 Ford Mondeo 2.0i GLX
19 Hyundai i10 - x 110
There was a Xantia for sale a while ago, a very nice 2.0HDi in silver, wearing Xsara Picasso Exclusive wheels. It really did look spot on in my opinion, though i imagine they use the same size tyres as the Xantias.
There is also a nice grey Xantia HDi on autotrader at the mo, wearing Xsara Desire wheels. So there are some other wheels which will fit and look good on Xantias if you want a change.
I very much doubt that 4007 wheels will fit a Xantia though.
19 Hyundai i10
19 Hyundai i10
Model PCD Offset Bore
C5 4x108 15 to 25 65.1
Xantia 4x108 15 to 20 65.1
Peugeot 405, 406 4 x 108 15...22 65.0
Peugeot 306 4 x 108 15...22 65.0
Peugeot 307 4 x 108 25 65.0
Focus 4x108 38 to 45 63.4
i be fairly sure that the 4007 is 5 stud
the reason that Xantia wheels are heavier than c5 wheels is that c5 wheels are alloy or aluminum or something like that
http://www.carlsalter.com/wheel_fitments.html
this site has quite a bit of info on stud spacings and pcd
http://www.1010tires.com/tiresizecalculator.asp
this site will help if you want to change rim size
Wheels
The centre bore sizing is quite important as thats what keeps you're wheels central on the hub and stops it riding along like a wobbley car like one of those things from the circus? Ie fords are size pcd 108 as pug/cit. offsets ok but bore sizes is alot diff pugs fit fords but not other way round.But don't sit central on hub unless you jacked it up and sets ages slowly spinning it round till you got it near right? but then it can still move on studs after you have driven it.
Plus i'd never try boring them out to fit as they'd be quite often after no good for any if you want to get shot of plus some of the alloy's have like a case hardening which you'd go through so left with a softer hole that can open out. ive seen it happen with bolt holes before and dealt with them comming a drift on the road.
But as mentioned if you go if you go up a rim size you need to go down a profile or 2 plus adjust with the width.
Zanty estates etc if you go 195/65/15 the speedo's about bang
xantia 19td estate 96-7
if you were to get a set of aftermarket wheels from a ford or a multi fit set you can change the ring that goes in the middle for one with the same bore as the citroen, but there are a lot of peugeots and citroens in the breakers with alloys so it shouldn't be too hard to find a set that will just bolt on.
