Does anyone know if the 2.1td starter varies in anyway at all from the TCT starter fitted to the ML5T box's?
In older cars Diesel starters(like for the R19 and R5's) were often fitted to petrols to help crank them over a bit quicker in the morning. I think this was due to teh higher compression ratio on diesels requiring more grunt to get them moving, and have been wondering if i could do the same with the TCT, as when the head comes off it wouldn't bee too much more work i reckon to swap the starter out for a better/newer unit.
Any opinions at all?
Starter Motors for the TCT
KP
- x 27
I've found out that the standard motor is 1.1kw and that there is a cold climate version on ebay which is 1.4kw which is the same power as the 2.1td motor...
Thats 27% more cranking power.... wonder if the wiring is upto the job of the higher spec unit or if an even higher one like 1.5 or 1.6kw could go in...
Are they even available or possible to rebuild in that way as i think its down to the windings in the motor if thats right and if there isn't enough space there won't be anymore?? could be way off as my electrical skills aren't that great anymore....
KP
- x 27
- x 8391
- x 1488
It appears that....:
2.0T 136 teeth p/no 053423
HDi 133 teetch p/no 053436 (noth 90 and 110 variants, despite the different box)
2.1TD Teeth not specified p/no 0532G2
1.9TD 136 teeth p/no 0532G5
So the HDi / 2.1TD ones are different no of teeth (I am assuming DTS means teeth....!) the 1.9TD is the same number of teeth, but don't know if it will be the same diameter. Might be possible to get an HDi starter and change over the pinion if you can get one the same make?
KP
- x 27
