C5 clutch pedal problem
michael maurice
Unread post by michael maurice »
Hi this is my first post.
I have a Citroen C5 2003 (52 plate) estate.
every so often the clutch pedal seems to go towards the floor, one time I found it on the floor, pulled it up by hand and carried on driving. If you pull the pedal up, it remains ok for some time.
The clutch is hydraulic on this car.
I'd be grateful for any solutions.
Michael
coastline taxis
Unread post by coastline taxis »
Could be rubbers in master/slave cylinder or pressure plate or thrust sticking. Anyway start with the cheapest and chang your clutch fluid as it only has a 2 year lifespan and il bet yours hasnt been changed so its quite old
Philjw
Unread post by Philjw »
I've had this on my 05 facelift 2l C5. I bleed a little fluid through the slave cylinder. It's been OK for about a month but the problem had only occured once before.
What have you tried and did it work?
Mine has done 87K miles and the bite point is getting a bit higher than it was when the car was new. I'd expect more miles than this before replacing the clutch. My last Xantia was at about 130K before it needed changing.
Phil
05 C5 Estate 2.0 16v + 05 C4 Hatchback 2.0 16V
viorelovidiu
Unread post by viorelovidiu »
this is all about replacing oil in hidraulic clutch? mine doesnt remain stucked but its coming back in steps with a noise of rubbing somewhere.
We could grease something behind the pedal, a shaft, or other things?
If I have to replace oil which oil will fit in there?
Citroen C5 2005 2.2 HDI 136cp Exclusive BVA
EX: Citroen C5 2005 2.0 HDI 138cp Exclusive
EX: Citroen C5 2005 2.0i 143cp SX
viorelovidiu
last summer I replaced the clutch. noise was coming from pressure plate...
flying clutchman
x 3
Unread post by flying clutchman »
Although replacing clutch fluid is'nt going to do any harm (unless you can't get it to bleed properly!) it's unlikely to be the solution for the pedal sticking down. It's most likely to be a fault in the master cylinder BUT that's only the % option, it could be a clutch problem. If it only happens occasionaly I'd be inclined to put up with it. Good job I don't give that advice to my customers!
cachaciero
x 9
Unread post by cachaciero »
Philjw wrote:I've had this on my 05 facelift 2l C5. I bleed a little fluid through the slave cylinder. It's been OK for about a month but the problem had only occured once before.
Clutch death at this mileage is not uncommon and if the clutch doesn't get you the DMF will :-(
Interestingly went to look at a 2005 2.0 ltr today 91K on the clock turns out that's just had a clutch and flywheel change.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
Philjw
May be tempting fate but....the problem hasn't come back on mine. Still nursing the original clutch and the milage is now 105K. It seems about the same.
Phil
