zx trailing arm bearings
tony1961
Unread post by tony1961 »
can someone please tell me the numbers for the needle bearings and seal for the zx trailing arm, or the bearing sizes thanks. tony
x 94
Unread post by citronut »
if you send me a chassis/VIN No. i will look them up on service citroen's site,
but if are not already aware the ZX is tousion bar suspension, and quite offten when the are bearing fail the cross tube is mangled beyond re/use,
so usualy the easyest fix is a second hand rear axle complete,
regards malcolm
