multispace rear window leaks
berlingo
Unread post by berlingo »
can anybody help ? all four hinged windows leak on my 2002 multispace ,bottom between seal and glass, just builds up and drips down side panel all four windows in the same place . thanks for any advice .
davek-uk
Unread post by davek-uk »
I'm not going to be much help, I'm afraid but...
Have you tried removing a window and cleaning up both glass and seal thoroughly to see if it makes any difference? It would give you the opportunity to examine the seal and the flexi hinges properly.
Another thought; is the seal joined at the area of leakage?
I have two multispaces and have never had this problem – although I have heard of it.
Dave
Pug Rifter long (20) - 41mpg - Gutsy for a 1.5!
Xantia 1.9 TD Temp.2 Break (97) - 208K@42mpg - Resting again.
Berlingo Multispace 1.6 16v (51) - 184K@36mpg - My shed! Still runs 15° retarded...
