OK I'm lazy and it's raining.
So just reading through the handbook for my C5 and a qusetion popped into my head about the Tyre Pressure monitors.
Citroen don't tell you a pressure just that the Tyre pressure is "OK".
So my question is what tolerance does the system give? My normal tyre pressure is 35psi at what pressure will it alarm?
If no one knows I'll do a little trial this weekend.
Cheers
Lee
Tyre Pressure monitor. How much pressure loss before LOW?
logiclee
2009 C5 2.0HDi Exclusive Auto. Storm Grey.
cachaciero
- x 9
The trigger level is programmed into the BSI this would allow the value to be changed depending on tyres used. Can't find any specific data for any tyre though
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
Homer
- x 16
R9UKE
- x 3
I didn't even know my C5 had tyre pressure monitors until I was driving along the motorway one day and it said "One pressure sensor missing". It disappeared straight away - must've lost contact for a brief minute.
Well I had the car for six months and never got any warnings... I did experiment in a service station - deflated the tyre completely to check for a warning; nothing - perhaps the car needs to be moving?
French is best.
JohnD
- x 72
As my towing trips are usually of several hundreds of miles, I raise the rear pressures up to 3 bar. After I arrive I reduce the pressures again. I've often wondered why the pressure warning didn't trigger when the air was let out, but eventually I decided the system had been deactivated. But then I recently picked up a screw through the tread. First time I'd seen the warning in 5 years.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
cachaciero
- x 9
It does, above a certain speed 20Km/hr I think the system samples pressure every few seconds or so stationary it samples about once every thirty five minutes or so. These figures are not gospel but it is the general way the thing works at least for the Mk1.R9UKE wrote:I didn't even know my C5 had tyre pressure monitors until I was driving along the motorway one day and it said "One pressure sensor missing". It disappeared straight away - must've lost contact for a brief minute.
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
